Mark, Interesting thread here, unfortunately the guys that are helping you are once again spreading BS info. Ted and Dave really need to get their cars running, unfortunately they've blown their crap up using their IC of choice, and have nothing better to do with their time other than attack me. I'm not going to argue here, it's unfortunate to once again be the target of these 2 internet trolls. Too bad, they have much they could do to help others but this BS doesn't help anyone. They started on me last year at this same time and here we go again..... Hopefully the mods and participants here will not allow this to go on again...
Now to once again have to defend my product, I will first tell you that we do not know what version IC you have, so to condemn it is obviouisly premature and more obviously shows the lack of concern as to what it is, since the AGENDA ONCE AGAIN IS PLAIN FOR ALL TO SEE. If you have one of our units older than 1 year, most likely it is our original unit from 4-5 years ago. It has been 8 and 9's on many cars with no issue and replaced several of the manufacturers that were mention above with better results and performance. I have worked on larger units the last 2 years, tested last summer and this summer and have had excellent results. As for what I use in the Pumpkin, I ran 8's over 4 years ago with the original unit and a Tubonetics T4-76 turbo for over 2 seasons before putting on a larger version of our design last spring. This year we have come out with new units that are more than comparable to anything on the market. I also offer custom built units to almost any dimension required. I would welcome a call from you to speak about your needs for IC and turbo.
Sorry to have gone off base, but I have no choice but to respond to this BS. As for the original thread, if you are looking to run low 9's I think since you are pretty heavy, more info about your combo would be needed. One point I'd like to make is you will require a substantial turbo to flow the air required to push 3600-3800lb car down the track. I'm in the shop evryday, feel free to call me anytime.
