- Sep 21, 2018
come off the fence and put one on,if you pull plugs and tune properly you will see that the plugs come out better with the plateim on the fence about putting power plate on read a lot of different opinions on it
nope usually in the colder temps more volume but it depends on timing as well.intake charge temps are a big deal as well.93 pump gas
About 15 lbs is all I can get without any knock , I thought for sure with outside temps below 50 I should be able to run close to 18 lbs
if you value not hurting the car i will tell you to not push beyond this without octane.not all 93 is the same and detonation is easily controlled with alky kits,e85,or race gas.it is easy to hurt the car on pump gas93 pump gas
About 15 lbs
Since 2002. There are many 10 second TBs here that run them.im on the fence about putting power plate on read a lot of different opinions on it
do you run one pronto
I have one on my car .Since 2002. There are many 10 second TBs here that run them.
This is exactly why I posted about pushing things.see you have volume with 812 but knock is recorded because you dont have enough octane.so you would have to pull timing around equivalent of knock and that's just for that pull as you drive more and intake charge temps rise on a street car knock may reappear.3rd gear pull 812mv @ 2.8 Knock S
