Magazine articles and videos are produced to sell parts.Two of the Mustang shops are notorious for not disclosing all the work performed on their "banner" rides.Press cars are the same.They have little changes to sell the product.Stone stock cars (properly run in) won't run the number.I'm not a believer in a lot of these tests when a beaten up press car may be one of the contestants. Show me a test where both store bought cars (properly run in) and unmodified by an owner or performance shop face off. I have not seen a new untouched coyote (for example) run the number (12.7 ish) yet. Nor have I seen a stock Shelby run the number.I'll bet that a proper race between Shelby and ZL1 would be surprising.
ROTFLMFAO........and we see that you've kept your car completely STOCK!!!!!!.... Should run mid 14's on a cool day!!!!!
EPH 2:8,9&10 Amsoil velocity stack,seq classic fast,(JS safeguard next),Ta61 (hsg's & wheels worked) & HD actuator,Tomka induction,RJC boost vlv,PTE s/l inclr(with reworked scoop),62mm t/b,matched stk plenum,RJC pp,Razor Alky,port int manif,port cyl hds (comp 980's vlv springs),steel shim hd gaskets (8.55:1),port exh manifs,Mease 3" d/p,straight shot,60#,,KB fpr,volt booster,Denso 280,hot wire & fuel lines,stock cam,worked trans,B&m trans clr,9.5"Precision 3000 n/l,HR bar,HR dr si mount, boxed uprs & lwrs,275/60/15 BFG's,bags,trunk braces,alum drums,s10 whl cyls,long shoes,weight loss program (car & driver), more smoke & mirrors yet to come.
