niiiice, that's one bad motor scooter, what type of trans do you run and are you foot braking or trans brake
Extreme Automatics 200.
Transbrake
Collin,
Good numbers! What was your AFR at peak power?
thanks,
Robert
I wonder if ud benefit from switching to a lockup converter
I ask Bc I have a lockup and am wondering if I should keep it or switch.
What rpm and boost r u leaving at?
more power to ya, i hope you achieve your goals.
What pos were you running on the chip and what fuel pressure?
Wow, those are some good numbers. Congrats.
my old combo was almost the exact same ,only i ran a 70 p trim turbo and 400 tranny .Is that a max effort R?
Mine went 10.30 @130
nice
Did you really mean a normally asperated crank??
Who did your machine work, how long have you had that crank beating on it like that? I was on the way to a 6.6? something before i let out of it right before the traps and floored it again right after and got a 6.72 1/8th 10.63 1/4 @ 125mph. I didn't make any more runs after that, I was just glad I was in the 10s:biggrin:
Good Job with you though especially if it's a NA CRANK!!
You threw a 67 turbo on there, and pushed it up to 26 psi, on a stock bottom end? You don't care if you blow out your bottom end?
