chazmat2316
- Jan 2, 2005
What's the fastest MPH anyone's gone with a Turbonetics 70bb-P trim 82a/r three bolt housing ? Just would like to what the max is!
YellaGN said:Good for you. Did you notice this thread is about the 70 p-trim? Not a 61. Do you have anything usefull to contribute, or did you just want to brag about your times?
c&cgn said:Gene Fleury went 9.9's @ roughly 136 - 137 mph with that turbo @ 30 psi. That was about 3 or 4 years ago, before the big dollar TSM guys started going 9's with their GTQ turbos.
Ted A. said:Right on that one. Wasn't Gene using a Stage motor for those 9 second passes?
JCotton said:Gene ran a stock block with a 208 cam and Champ alum heads, stock rods and crank, he made a bunch of 9 second runs before he found the block webbing cracked....... his turbo was a Tnetics ball bearing P trim with a Tnetics .82 exhaust housing. No stroker kit, no race ported hoged out heads, no cam as big as what most run in stage 2 motors, no distributor, no turbo 400 with a trans brake, just a little 200r off the foot brake... if he could do it, I would think others could as well without breaking the bank.... I would like to add, running the big number requires great tuning and a 60 foot to match.... not an easy task
chazmat2316 said:What's the fastest MPH anyone's gone with a Turbonetics 70bb-P trim 82a/r three bolt housing ? Just would like to what the max is!
