turbofabricator
- Mar 7, 2004
I have re-used the Cometics THREE times and removed the rivets and cleaned each layer, then sprayed Copper-Coat. This last tear-down on a 14 bolt StageI, the #2 cylinder was split (again) and the head gasket was perfect. Not going to use them again, though. Just call me paranoid. One issue with the copper-Coat was a breif scare on first oil change. There was copper dust in the oil. I cut the filter aprt and there wasn't any bearing material in the pleats. So we concluded it was the copper coat on the gasket that overhangs into the lifter valley. At next oil change it was gone. But at first I thought I lost a cam bearing. On tear-down all the bearings looked new. (first time EVER for that with this engine
) The cylinder wall was split becasue there was a crack in the hose going to the MAP sensor for the Alky system. First time it saw 22 psi boost it knocked HARD. Found the problem and fixed the hose, but the damage was already done. It still ran 10.12 @136 on 22 psi, pump gas and dual nozzle alcohol, and a split cylinder wall. Pushed water out of it durng each pass. (go figure) I thought it was the Cometic leaking, but it looked brand new ('cept for the copper coat) and there was ZERO leaking past the gasket. So, with 6 studs per cylinder, smooth deck, and smooth TA heads, a Cometic will hold enough pressure to make a 3" spit in a cylinder sleeve. (.090" iron) The block is being sonic checked to see if there is a real thin spot in that area. A Darton sleeve will be used this next time.
