I thought the whole point of the plate was to even out air distribution to the leaner running cylinders. Shouldn't that "up" the power and increase durability?
That's all it does, even out air flow. I don't think it's advertised to do anything else.
The other benefit of the RJC Power Plate is knock retard reduction.
so is there no need for the PP with a set of ported heads and intake from Champion with ALKY?
As i mentioned earlier in this thread i use the power plate and i have GN1 aluminum heads,ported intake by Champion,dual nozzle alkycontrol,Maftpro SD setup,and 25% e85. I can run 20 lbs boost on 93 octane only.
To be a little more specific about just what these Power Plates can do. Say if you have a stock or a slight build running on 93 pump gas. You are most likely at WOT between 4 to 5 degrees of timing retard on a properly running engine. Mainly cylinder 6 and 3 are the culprits of KR since they will be the leaner 2 at WOT. You are already losing timing and hp at this point. Putting the head gaskets in the red zone comes to mind also. The PP addition at this point most likely will eliminate 95% of timing retard by having all cylinders with even airflow. You will also be able to get away with 2 more lbs of boost since there is more room for air with a spacer. The car will feel faster now because there is no timing being pulled back. The PP itself did nothing except provide a little more air space for the plenum. It just simply allows the engine to run more efficient but feels like you added 50hp. Now if your have alky kit, SD chip or E-85 it's probably not going to do much for you.
These engines are notorious for leaning the rear two cylinders. 27 years of trying to prolong life and produce better power have proven it. I have never heard of any issue with any other cylinders leaning out in stock form.
Could you please provide more detail about your combo.I have an engine on the stand with ported GN1's, just want to run pump gas on the street but I think the Hemco was a better solution for air distribution than the PP.It has also been strongly suggested to me not to race with the PP on the car.As i mentioned earlier in this thread i use the power plate and i have GN1 aluminum heads,ported intake by Champion,dual nozzle alkycontrol,Maftpro SD setup,and 25% e85. I can run 20 lbs boost on 93 octane only.
