just posted something for you, go take a peek.
Bob
Hey Bob, In the analog 4 and 5 drop menu there is a option for volts. On the graph, the ceiling is 5 volts. Is it possible to make that user configurable up to say 16 volts?
I want to see if the voltage that the ecm is reporting is consistent with other things in the system. I have an issue with ecm voltage dropping down into 12's at wot.
I see this on allot of other peoples data as well.
they should be right for Razors sensor
you define the endpoints of the measurement range, like how an LC1 is set up.
If I remember the specs right, the sensor is 0 psi at .25 volts, and 150 psi at 4.75v
the gauge ranges don't do anything yet. the graph min and max set the top and bottom of the graph display.
so, that looks like:
CustomAnalog5GraphMin=0
CustomAnalog5GraphMax=150
CustomAnalog5MinValue=0
CustomAnalog5MaxValue=150
CustomAnalog5MinVolt=0.25
CustomAnalog5MaxVolt=4.75
CustomAnalog5Name=Pressure5
this is what shows in the selection dropdown on the F3 page
CustomAnalog5LongName=Analog Input 5 Pressure Sensor
this is shown on the graph when viewing the data
CustomAnalog5Tag=PR5
this is next to the numerical reading of the data.
Bob
i changed my alky pressure to 0 min and 250 max. i guess this wont read right if 4.75 = 150psi or will it read 250 at 4.75
[CustomAnalog4]
CustomAnalog4Name=Alky Pressure
CustomAnalog4LongName=Alky Pressure Sensor
CustomAnalog4Tag=PR4
CustomAnalog4GaugeMin=0
CustomAnalog4GaugeMax=250
CustomAnalog4GraphMin=0
CustomAnalog4GraphMax=250
CustomAnalog4MinValue=0
CustomAnalog4MaxValue=250
CustomAnalog4MinVolt=0.25
CustomAnalog4MaxVolt=4.75
[CustomAnalog5]
CustomAnalog5Name=Fuel Pressure
CustomAnalog5LongName=Fuel Pressure Sensor
CustomAnalog5GaugeMin=0
CustomAnalog5GaugeMax=100
CustomAnalog5GraphMax=100
CustomAnalog5MaxValue=100
those settings would be correct for a 250 psi sensor.
I need to contact Razor again and see if my notes on his sensors are correct.
Bob
his transducer is a 150psi unit
