If you do it right you can get a used stroker that is already done at half the cost it would be to build your own.
I picked up a stroked short block for 1,500 with only 4,000 miles on it. Steel crank and rods and center mains.
Roller cam and lifters front cover cam sensor and all acc, including AC and turbo saver.
Mine came with the build sheet with specs and clearances and all parts used.
I spent another 350.00 having it cleaned/checked and new cam bearings and a hone on it.
It's a standard bore SG block that was built by WEBER and I needed to fix one screw up that they made when they assembled it.
I know that's not the norm and I got a good deal but if you keep your eyes open you can find them out there.
It has been the best money spent on my car except for the Lonnie stage2 trans and custom converter.
I do consider it a better block than the 109 and the extra arm in it is a bonus even it's just a little one.
