I never got new ones, I used my stock ones.... But Conrad (HotAir) has ordered new ones shoot him a PM and he can tell ya what he bought...On the 4 cross shaft bolts, how long 7/16" bolts did you get? My stock bolts are in Arizona and forgot to measure before I left.
Give us a call at the number listed on the banner in my sig...Hi Scot I'm upgrading my front suspension I have stock spindles and tubular upper and lower arms will the before I get the coilovers I just wanted to make sure I would not need to select specific size or weight for the front coilover setup thanks ,George
A) Caster slug placement is shown in the very first post of this thread ( Picture showing how they need to be installed )..... The arrow on the upper cross shaft shows the direction the upper arm needs to face (Forward)...Almost done installing everything including baer brakes.
Only thing that wasn't clear is do the caster slugs face towards the wheel or engine. However I think I understand the direction and installed them with the caster slugs facing the engine.
imop ridetech should put some torque specs in the instructions.
Had to get bolts for the uppers as the stock ones don't fit. Also my upper spring pocket tabs had to be cut as the coils would hit if I didnt.
Hardest part was getting the old coil springs out.
Baer brakes were simple.
Also the stupid upper control arm nuts suck.
Does it matter when adjusting ride height if one spring is compressed more then the other side? Figured mine is off on one side because of the pre load non the hrparts rear bar.
I have to pre load one side more then the other to get equal rode height
