- May 28, 2001
Looked all over for you....I will be at Bowling Green on the river side with a 30x30 tent and a WH1 with NY plates " IBOOSTN " .
How'd you make out?
We were right where I said , river side of pits 20x30 tent ( they ended up giving me a smaller tent ) in between I believe it was Turbo Farm's big RV and Champion Heads trailer . The tent was set back to the edge of the grass with the trailers sticking out on either side . Too bad I missed you , maybe next year .Looked all over for you....
How'd you make out?
Seat time and your thereWe were right where I said , river side of pits 20x30 tent ( they ended up giving me a smaller tent ) in between I believe it was Turbo Farm's big RV and Champion Heads trailer . The tent was set back to the edge of the grass with the trailers sticking out on either side . Too bad I missed you , maybe next year .
Only got to make 2 runs all event due to the weather. First run was a shake down , new to me , easy 2.0 60ft launch then going to WOT . The car started pulling harder the ever before then started to stumble so I got out of it as soon as it started .It was at the top of 2nd gear when I saw 6170rpm and it stumbled , not sure if it was rev limiting or not , turns out it was very rich , may be a sparkplug issue . My tuner made some remote changes , lowering boost a couple of psi and wanting me to try and make a clean pass but don't go WOT . Trying to make a almost WOT pass is difficult when the car pulls so hard with my small foot ( size 7.5 ) coming on & off the throttle all the way down the track ! You could hear it the whole run and the data log showed the TPS and boost following my foot input . An easy 2.1 60ft , on and off part throttle , boost 25psi ...11.50 @ 132mph . LOL . I really wanted to shake this out on Wednesday but the weather wasn't cooperating .
Out of curiosity, how much co2 for how much boost and were you running a spring in the gate?we literally needed not alot of dome pressure(while getting the co2 where it needed to be)to create boost and the boost pressure made power while being lowered.
That is doing pretty good. I have a 5# spring and 20 psi on the dome only gets me 19psi with my HPT-6466It has a 9 lb spring & 20 psi dome pressure .
That 9# spring & 20 psi on the dome netted 28.1 psi boost .That is doing pretty good. I have a 5# spring and 20 psi on the dome only gets me 19psi with my HPT-6466
wow, that is actually really good. That turbo seems like a winnerThat 9# spring & 20 psi on the dome netted 28.1 psi boost .
Curious Spool
What's the spool gain C02 vs vacuum that you've noticed in general?
C02 appears to offer a bigger gain than I'd expect in this category let alone the precise boost level adjustments.
CO2 gives great control while keeping the gate shut better than using manifold pressure. Spool up is stupid fast for me anyways and that comp turbo seems like it is even better. It's also a stupid easy to install. I mounted the bottle in the trunk, ran the line from the trunk through the side of the back seat then in to the wire channel under the doorsill coming out to the engine compartment AC wires/vac lines are and I mounted the solenoids on the pass side inner fender.Curious Spool
Many of us up here have usedCurious Spool
For my cars or Sam's?Out of curiosity, how much co2 for how much boost and were you running a spring in the gate?
From what he said it was 9# spring + 20psi dome was 28.1psi which is REALLY good. (almost 1:1). With my hpt 6466 on a 5psi spring and 20psi dome I am at 19psi (1.3:1). I haven't turned it up since I have a 200 mile trip with the car coming up that is going to be on gas instead of e85.For my cars or Sam's?
Yes we saw 1to1 at 900fwhp on Sam's carFrom what he said it was 9# spring + 20psi dome was 28.1psi which is REALLY good. (almost 1:1). With my hpt 6466 on a 5psi spring and 20psi dome I am at 19psi (1.3:1). I haven't turned it up since I have a 200 mile trip with the car coming up that is going to be on gas instead of e85.
Take a look at your fuel usage at 1.3 bp and 19psi.From what he said it was 9# spring + 20psi dome was 28.1psi which is REALLY good. (almost 1:1). With my hpt 6466 on a 5psi spring and 20psi dome I am at 19psi (1.3:1). I haven't turned it up since I have a 200 mile trip with the car coming up that is going to be on gas instead of e85.
