The First Comp Turbo CTRX Hubless
Ok
We are still testing on Sam's car
But I will release some lower boost numbers
At 28.1psi the car made 860hp with the backpressure at 1.1🙂
Low boost numbers :LOL:
What are the converter spec's and how is it doing on slippage ? i see its Dave's but unfamiliar with that version, 3521?
The converter is a custom diode NL . Dave has only made 2 of them and mine is spec'ed for my motor that he built . As far as stall I'm not sure because It was restalled after the Comp 6771 CTR was installed , Mr Spool has that info . The car is going out tonight for some launches & WOT blasts , then to the track on Saturday .
Curious how the weekend went?
The weather didn't cooperate plus few minor set backs , Found a bad Holley coil that was causing issues then blew off a charge pipe coupler . going back out shortly . Mr Spool will post results after final testing .
Yes I will post up when we are done with the testing getting it where it needs to be.
The Holley is showing boost being made at 1800rpm.
The car rips.
