RICHIE HIGH PSI
- May 25, 2001
Maybe i missed something??
Are you bragging, or disappointed?
When I get the car to a better track, I will be turning it up. I too believe there is more in it. I have had the car at a good track lately, but didn't have time to play around with the boost curve. Besides, it's really just recently that I've come to the conclusion that my home track is a large part of my 1-2 shift problem where the tires want to break loose above a certain boost level.Don - In my opinion nothing you have mentioned should prevent you from running 8s. I would agree with Chris Lyons about turning it up as I too believe there is more in it. I've seen your posts over the years, and you have to admit with as much testing as you have done with that combination, you eventually would have to run the number. Its a matter of you choosing to take the longer and less traveled path to get to the same destination (8s). I don't like to travel as much, and so I threw a run of the mill 274ci S2 with Stage heads in my 3400lb car on 275 radials with stock suspension and a 10 bolt rear end with an 88mm turbo (with a 1.08 exhaust housing) I went 8.40 @ 166 with a soft 1.42 60 foot my second trip to the track.
Now I've broken some parts and learned some things trying to keep it together this season (also had very limited time at the track with the car due to taking long to make minor repairs myself) and expect to run much faster in the spring, but am sure that when you turn yours up you will find it can go faster as well.
But, what is it that is right that is allowing me to do 8s? Not everything can be wrong, yet I'm doing 8s with a 1.835" intake valve.What your slips are telling you could be that something is right... or that something is wrong... depending on prespective.
Did you read the first post? I'm wondering why my combination is allowing an 8 sec pass with a 1.835" intake valve.Maybe i missed something??
I would imagine it would.And you wouldn't make any more power or go faster with 2.10 valves?
I don't think you understand the answer I'm looking for. Why has the car been able to do 8s even though the heads only have 1.835" valves?Well there is your answer. You would agree then that these heads are not the cause of your performance to date, but rather that your combination was able to achieve the performance it has DESPITE the 1.835" valves.
Theres prolly still more in it, and when you reach a point that it can't make more power with what you got, you know switching the heads will free up even more power.
kidding aside,im sure that 91mm turbo at 31 psi is providing lots of air and easily has more in itfrom the gears,boost,meth,rpm i think that everything you listed is working together and that it is not just one part.from the gears,boost,meth,rpm
Not kidding around, guys. The info is correct and the question is sincere. I'm looking for the answer. There are plenty of capable people on this site. Someone has got to be able to come up with an answer.Come on don, i read both pages and still you havent coughed up the answer. what is it?
