Joe Lubrant
" The Right Stuff "
- May 25, 2001
NCTURBOS said:I see that as well, but all that does is complete the "loop" back to the "Y" down below the alternator.
So those (2) lines that come off that "Y" to both sides of the rail are feed lines correct? Or does the "Y" have some kind of check valve in to force the fuel feed to one side of the rail, and then return back the other side??
K.
Yep.......See the feed lines on both sides, and the Regulator....but No return line
Normaly if fuel is fed to front/both sides of rail, the Reg & Return would be at the rear of the rails
Am I also missing something
