Maybe to you, but you're not the one running things are you?.
Maybe then you should read up on the material, and then try to discuss it.
The type of ecm was never an issue with me, I was talking about the code end of things. If you like not having any choices, that's fine, but then again, not everyone thinks like you. Paying $400 for a $150 sensor, fine go ahead, but, that's also your opinion. Maybe you just like to throw money around, but again, not everyone might.
So dropping spark and leaving fuel around does less cooling the dropping the fuel?. I guess then we just hope when your spark comes back on, there's just not too much fuel laying around to drop the EGT even more, or blow the plug out completely, or worse yet partically. Then all you know is that something was off, and not exactly what.
As far as fact and the EST, I guess ignoring my response is one way of saying it can't be done. Anyway here's a quick explaination, the Quick Start uses two shutter wheels on the crank. One has 3 windows, and the other 18. The windows overlap differently, ie the inner one before the outer, then at one clocking of the windows they open at the same time, and then the third option is having the outter window open first. That way the module knows exactly which coil pack to fire, at the next *point open* signal the ecm sends. Does that explain it well enough?. Oh, and just for grins, with that type of set-up, one could also set up a misfire detection system. Wouldn't it be nice to know after a pass, which cylinder was laying down, if there was a problem, or better yet, have the computer tell you which one was *off*, even if you didn't notice it?.
Just to back up a little and try to get back to the original posting, *HAVING* to change to a distributor just to get some options, can be cured with some simple code changes.
As far as the 100 HP claim, on a 1,500 HP engine, while one might wish that it means 50 HP on a 750, if just as easily could mean 0 HP at 1,300 HP. Not to mention no one's said if it was a stock DIS to CD Distributor comparison.
Maybe there needs to be some rule changes to allow Magnetos, and carbs in TRs, since Top Fuel uses magnetos, and PS uses carbs...
