norbs said:Maybe I'm confused here but the stock ecu does not cut the est signal at all, but is just a fuel cut, like the fast system. Correct Bruce? So no factory "code" will do anything if this is true?
bruce said:From what of set-up?.
ie stock DIS, late model DIS, one cd/coil pack?.
quickt said:The stock 86/87 C3I unit. When you drop est it looses cam sink. How can this be corrected with code?
quickt said:The unburned fuel is what helps the turbo to spool up even at a low RPM. Example.
If I two step my car in park with the dist. it will build boost under no load at all. This happens very smooth. How can this be done with fuel cut?
norbs said:Here's your answer:
bruce said:So?.
You consider running an intermittent ignition cut, as being smooth?.
Of what purpose does building boost under no load, a benefit?.
You seem to be stuck on the idea that the only strategy is interupting the EST, and it's not.
EightSecV6 said:Put a clutch in it, you'll see!
bruce said:So?.
chevyII said:Not to sound stupid but the EST line to the module is the final output from the ECM to the module for timing advance correct. In the older cars you always unplugged the EST to set base timing right off the triggering device. So if the EST line is not working or interupted your just running on base timing/or no ECM controlled advance. Seems like were beating a dead horse. I replaced a thousand coilpacks and modules on stock vehicles. They die faster than flies,the more we try to strech the limits of stock parts the more they will fail. I just bought a stage 2 with the coilpack and coils on it there going in the garbage and going to a dist. Why because they wont hold up period.
DR.BOOSTER said:I will say this Bruce, its pretty damn cool how you got the stock ECM to drop all that timing during brake boosting and then have it come right back as soon as the brakes released.![]()
That thing must spool like madd.![]()
It looks like you are only torquing to about 2500 and then letting it loose.
Whats stall is in the car?
Turbo?
What psi are those launches at, the 3-4psi that you mentioned above?
I could not find a consistant place where the ecm was seeing when to drop all the timing, it appeared as if around 20% TPS is dropped. Are you doing it at a specific TPS at 0mph or a combination?
Pretty cool to say the least.
Now why can't you sell these ECM's Bruce??![]()
Seeing a manual spool and get boost due to a studder box was pretty cool, the DSM's and now leaving at 4500rpm and around 5psi.![]()
