009s to 50s
bsdlinux
Just Another BLACK Car
Hey wanting to upgrade to 50s. The 009s are ok, but I have heard too many good things about the 50s. Considering my setup am I doing the right thing or should I get a different setup all together? Need feedback.;)
Sounds like you've got just the ticket for a set of 50's!! Might even think about going up a turbo size or two, to match the high flow mods that are done. You'll also need to think about upgrading your intercooler at some point. Got a lot of potential there.
10-4 on the intercooler. The TE-60 will definitely push the stocker over the limits, stuttttter.........
If you are trying to go to 11.0, then the 50s might help...bigger is only better if you need the fuel.
It's not that big of a steup up really. Why not save your money for now and run the car as is. Once you hit 11.30's or 11.20's then look into upgrading injectors. I suspect once that time comes you'll want to go alot faster and will probably end up buying 55's or 72's etc.
