009's with Armstrong Chips 3300 miles
vader t
I have a set of 009's (42.5) injectors available with your 2 choices of Red Armstrong's 93, 100, or 107 chips. The injectors only have 3300 miles on them, they make a great upgrade for someone. $175 shipped to your door.
specs on 93 chip?
I'm interested, can you shoot me the specs on the 93 chip or what you were running with it? Just want to know if it will run good with my combo. Thanks, Gabe
The 93 chip is primarily just for street applications. Its a relatively low timing chip that works best with 17-19lbs of boost. The last time I used this chip at the track was when my car only had a couple bolt on's and the 44 turbo and i was running between 12.5 and 12.6. The 009's are great and actually flow more at full DC than 50lbs. Let me know. This is an inexpensive way to pick up some hp potential for cheap.
Would have taken em...
Thanks for giving me the opportunity to respond, I guess I didn't say I'd take em... my fault. :(
