-0016 block 4 bolt splayed caps, half filled, one repair on the side(see pics) was magged And sonic checked ok.
-BMS 3.625 crank
-Carillo 6.5 wide journal rods
-diamond custom pistons and custom fit rings
-king bearings
-Chapman ported s2 heads titanium valves come td rockers
-converted s2 intake with fuel rails
-s2 comp cam 246/246 w thrust plate
-solid roller lifters w pushrods
-Buick valve covers s2. One has breathers on it
-S2 front cover w msd crank trigger and water pump
-fluidamper with magnetic pickups
-S2 atr headers that need fixed. Driver and crossover are ok but somebody did some ugly welding and cut the flanges off the pass side.
Bottom end was machined balanced and assembled by Mark small machine. It's ready to go. Heads were also gone through by them. Fresh valve job. Seat pressure is 240#. Have all receipts. Only thing this motor needs is an oiling system and headers fixed. Any questions contact me here or 4106934472. 9000$ obo
			-BMS 3.625 crank
-king bearings
