Jan Larsson
 - Nov 22, 2001
Just to see what you all think, I'm no tranny guy and try not to mess with them on my own if I can avoid it however when I had the tranny rebuilt many years ago I was told one of the two bolt holes for the 1-2 accumulator housing had poor threads and when I replaced the filter and oil a few years back I did carfully feel both bolts and one of them did seem like it would just rotate if I would use a wrench on it.
I have since noticed when driving slow (30-40mph) that I get a bit of sluggish what appears like down shift then quickly back again ... not sure if it's shifting down or not but it feels like it but just for a second or so ... not had a scan tool in the car at the moment to see if it actually do shift or if there's something else going on.
So the question would be if the housing is not properly torqued down and it's "leaking" around the gasket area (or the plate down there) what would be the symptoms?
And next question would be can I helicoil the threaded hole without taking everything else apart (thinking about the valve body and plate/gasket) ... ?
So the housing I'm talking about it no 929 (in red) in the attached exploded illustration held in place by 2 bolts.
Any help much appreciated.
