1-2 shift problem
QUIP'6'
Brian Roman
after 2 years of running perfect i went to the track for the first time with stroker and billit tranny and launched on 0 boost and when i get to the shift point it bangs back and forth hard 5 or 6 times then shifts then shutters down the track. i had a 1.8 60 foot and left off twice and got a 11.66 at 117 with 20 psi. on a te60. my car shifts soft cruising into second and third takes forever to shift. power logger file here
Brian, call Vince in the morning. If it has anything to do with the transmission he will know and take care of it. I bested an 11.25@119 today after you guys left. The guy with "issues" made another pass and I figured he would come back to my trailer, but I think he just left. So not sure if he turned the boost down or what he ran. But I figure it wasn't good.
I'm pretty sure you threw the governor spring while doing a burnout. This is known to happen then while making your pass your hitting the rev limiter. Shifts will be very delayed when the spring gets thrown. Have a look in the trans pan you may see it there. This bucking you describe can be very bad especially if running meth, it will still spray and can cause a very lean condition. Hopefully you didn't hurt anything.
nice pass. Called Janis and he gave me attitude. Got to my road at home and heard a pop and a major exhaust leak blew gasket out toward header on number 3. Felpros suck.
if you look in log file it is shifting at 5280. It seems like its trying to hunt for a shift. Then it feels Luke the band is pulsating on the drum.
Sent from my SCH-I100 using Turbo Buick
