Ok guys, I need your help on this one. I have unsuccessfully tried changing the timing chain (first time). When I disassembled everything I thought I had it at #1 TDC. After removal I noticed the gears were not line up dot to dot. I then put on the crank bolt and turned by hand to line up the dot's. After reassembled and trying to set the cam sensor numerous times I have not been able to start the car.
I went ahead and removed the drivers side valve cover so I can view the valve springs to help find #1 TDC. I understand the two should be closed. Does closed mean compressed or decompressed?? I noticed as i turn the intercooler fan both do not compress at any given time. Is this correct?
Can you guys tell me where I'm at here. Do I need to remove the front cover again.
Help!! Figures my luck
Dannyo
Dannyo
