Turbo6Smackdown
- Dec 31, 2005
Ok, first question is, does gm part no. 25525315 (one way check valve) hold up to 25 psi of boost, or were they just barely adequate for 15 psi back in the day.
Question two. If my cruise and all the other stuff that's operated by vacuum relies on vacuum, then what does it do when the check valve's closed due to a positive manifold environment? Does boost getting into my cruise control system due to a leaky check valve screw with the way my cruise works?
