10 sec. 87 T Show N Go
RUQWKNF27
Car has org motor an tranny with around 88K on chasis..
MOTOR// is as follows.. 30 over with Je Pistons//. RJC Girdle,// RJC Oil Pan,// TA Performance HI PERF. Front Cover with Adjustable Oil PSI.//New water Pump//Cam is a COMP Flat tappet 268H-218/218 Cam//All bolts are ARP.Motor was Built by Dusty Bradford off the board. 1900 mi on motor
HEADS// VPE St. 3 Port work. Fully ported intake runners,exhaust runners an reshape combustion chambers.Manley severe duty 1.775 intake valves an 1.500 exhast valves. heads resurfaced an Teflon valve seals installed.. Comp Cams 980 1.250 Valve springs. Intake Manifold fully ported an EGR tower removed an blended.@ .450 Valve lift heads flow 206 Intake an 173 Exhaust CFM.
TRANNY// Century Transmission . Hardened Parts with Alto reds. Trans Brake, Art Carr Deep Pan. PTS 9/11 3400 stall lock up. Trans Cooler. 5000 m.i. on tranny..
SUSPENSION// Air bags. Front upper an lower braces. Rear seat braces. HR Parts upper an lower braces. KYB shocks. ATR Rear Bar, DS loop. Ta Performance Rear Caps Cover , Moser axles.
WHEELS// Conve Pro 15x7 an 15x8.5 with New MT DR's 275/60/15 an new BFG Front radials. maybe 500 m.i. on them.
STEREO// Brand new installed yesterday. Pioneer Premier CD with remote MP3 capable. With Polk 3 1/2's up front an Kenwood 6x9 4 ways in rear deck. I had (4) of them installed in cutom made board where hat rack used to be. Being pushed by Kenwood 4 way 600 WATT amp.. Sounds Awesome.
AC// Had new AC installed with new Savannah Auto supplied parts last week!! New Compressor new hoses , new blower an wheel, drier everything 134A. Blows hard an cool. Radiator is a Arizona GN unit with Dual SPAL Fans filled with RMI an destilled water.
TURBO//LIMIT ENGINEERING INC. TE45A .63 PTE 1" W/HP ACT P-trim 1900 m.i.
FUEL// 72 lb. Siemens With Racetronix Hott Wire Harness. Double Pumper with 340's Underhood gauge.
INDUCTION// 4" BUICKGN Mark Huefmann Cold Air intake with 9" Pro Flow Filter 85 mm Maf, Tranlator +. an Extreme Chip. Polished 70 mm RJC TB an Plenum. CAS V-2 with 3" Pipes 4" MAF PIPE
EXHAUST// 3" TH DP an Cusom 4" Single Shot with Dynomax Race Magnum
Previous Owner took car down to bare metal as can be seen here>>http://www.cardomain.com/memberpage/637073/2.. New Carpet + much more.. Car is a bench Seat Column Shift but I have buckets in it now. Still have bench. New Windshield an all trim has been Powder Coated BLK. Tint is 15%.. New Door Seal Plates. New window Felt an Door Rubber an Trunk Rubber.. Roll - up windows with Electric Trunk release.. Has custom Hood Liner an Trunk Kit. Has Line Lock also.. I am sure there is some I am missing but I am tired of typing.. Car has ever been wrecked . But I was cut off last Dec. So I had to swerve to miss the car an hit a curb which in turn pushed my front left wheel in the fender denting it. It could have been repaired but I replaced the fender plus all the front left suspension pieces with NEW parts.. You would never know if I didn't tell you but I would want to know this if I was buying a car.. I also have one brand new 15x7 convo buy org. is fine.. Price is 23K. car will run 10"s with more boost an tuning.
Fiberglasss bumpers front an rear with aluminum supports. HR parts motor mounts urethane, Gel Battery in trunk. New mini starter. ARP Studs on heads. Champion Valve Covers.True Double Roller Timing Chain, Billet Fuel Pressure Regulator, New Springs on suspension,Viper alarm with trunk release. Just some more I thought of!!
pic
Well it is not sold yet Chris!! If I sell it I will get over it like my 1st GN I sold..
I know the price may seem high for some but there is not a stone that has been unturned on this car. I look @ Tr's that are for sale all the time so I kinda know what they go for.. An rarely I see a car that has been done allthe way like this one.. Sure there are low mileage cars out there that are stk. that people may think deserve this kinda money over a car like mine. I say to them buy that carwhen you find find it you won't regret it . ;) But as for this everything has been done an you can drive it anywhere. Only thing that I did not do was the 20" TT II's in Black for wheels. Who knows if it doesn't go I may still do that. :eek:
Your are right! I have seen this car and it is the NICEST TR that I have ever seen! I has ALL the go-fast parts and is just beautiful. If I had the cash, it would be in my Garage! If any one wants to ask me about it just drop me a line!
Do you still have the 16" black TA wheels? Would you throw those in? Will you post some interior pics? The car looks great, I am interested, I just can't tell my wife yet, she was not happy when I brought home #5 in our collection but maybe 6 will go over a little better, I have wanted a really nice white TT for ever... Thanks!! BEN
6 New AC lines an Compressor etc,,..
