SignUp Now!That's not that bad.. No transbrake. At that cost level can it hold up to high 9s? It being mostly street?3100+ depending on gear sets and Trans brake options
Exactly that's why I went th400 built from ck performance 5 yrs ago still going strong , and put the 4,000 toward buying a forged rotating assembly n Rjc girdle still going strong in the tens at 3800 lbs full weight .Its about 4 grand to build it right. Or is it more these days?
You will be fine with a stage 2 or 3 Extreme Automatics 200 then...Thanks for the great info! The truth is I don't even know how much power I will be making. My new build is 109 .30 over all forged girdled gn1 race port with stock ported intake 214/214 fast ramp and 64-66 .. So if the 200r4 can handle that I will stay with it. Also it is a street car 95% of the time and it is not a daily driver. Probably should have said that to give you guys a idea of how it is used and I don't beat on it all the time.
Thank you!!You will be fine with a stage 2 or 3 Extreme Automatics 200 then...
