Apr 30, 2009 #1 R robk46 New Member Joined Jul 19, 2006 Messages 238 Like new, except where someone went nuts holding the end of the rod with a vice grips and chewed it a little bit. I have pics. $40.00 plus shipping.
May 8, 2009 #2 B bholker Member Joined Jul 14, 2001 Messages 33 Will this work/mount with stock turbo? Not familiar with the "1011-144" is that mfg part number? More info if you have that, I'm interested.
May 8, 2009 #3 R robk46 New Member Joined Jul 19, 2006 Messages 238 Yes. This is the stock replacement wastegate actuator that works on the stock style turbo. It starts at 18lbs of boost and can be adjusted upwards from there. It's basically the same as a stocker, with a stronger spring and an adjustable rod.
May 9, 2009 #4 R rev. 3:11 "BEHOLD! I COME QUICKLY..." Joined Apr 2, 2002 Messages 824 If bholker passes I'm interested! D
