SignUp Now!Low 12s/high 11s would be around high 7.5s/low 7.6s in the eighth. Anyway I'm working towards that goal also, see my website for minor mods. In addition next year I'll try a Thrasher 108 with more timing (currently Thrasher 100), HD actuator for 23 psi (currently 21 psi), port the turbo exhaust housing, and box the LCAs. I think the 60 foots wound need to be at least down into the 1.6s to achieve your ET goal.Originally posted by 5ltretr
Looking for some guidance here, I wanted to keep the stock turbo and see if hitting 11 something is possibe. Any recommendations????
Thanks!
myles
Once you get into a higher boost launch, Kevin's suspension setup should get you into the 1.6s. In fact, it's something I'll try along with the boxed LCAs. If I had Kevin's 60' time, I could definitely be in the 7.6s. I can't launch over 5 psi without losing tractionOriginally posted by KEVINS
although the suspension work I did gave me an all time best of 1.61 60'. I am now back to my original timing and I feel that with a higher launch boost I will see the 11's. If not then I'll get a better IC, either a big neck or a stretched unit and that "should" put me solidly in the 11's.
I have detailed everything on my web site in my sig..
ks![]()
