Please diregard my sarcasm, but this car has me at the end of my rope. I put a push rod through a rocker a few weeks ago, so I just changed both banks with Sealed Power ones from Postons along with 5/16" pushrods. Did the job correctly by starting at the left and proceeding LR LR LR, torqued them to 25ft/lbs in the saddles. Go to the track last night and the car is dead in the middle of the run, it just falls flat on it's face. Had 110 oct, 16-20lbs of boost. 02's were good, got knock the first run. Ran 15.79 @ 85mph, 16lbs 7.7` knock. 2nd run 15.2 at 86mph 18-19lbs no knock fell flat again in the middle. 3rd run 19.77 @ 78 (let off), no knock 20lbs. Launched ok with little boost but fell flat after 100'. Boost is there but car will not pull it just seems to die. My signature has my list of parts and I have always replaced parts with factory or better. It is not the valve springs, they have been changed with comp cam ones. Car was flat at 4500rpms when they were bad. This is a different power loss. What do I look for? Could I have done something incorrectly on the rocker arm assemblies. Car seemed to do this before the pushrod began ticking real bad and I pulled the valve cover and found the #3 intake through the rocker arm, Obviously the tick is gone now but this new and I have no idea where to start. I read all I can before I approach doing anything on this car, but I fix one problem to have a new one appear. If there is anyone in the AKRON, OH. area who has good knowledge about these cars, please contact me so we can hook up and maybe you can figure this POS out. I love the car but I am emabarassed to put it on the track and literally tarnish the reputation that these cars have earned. Any suggestions are welcome and if more info is needed I can provide that too.
