Jan 8, 2013 #1 J jmendlik Active Member Joined Oct 1, 2001 Messages 806 will these 120 lb injectors fit/work with stock fuel rails w/o any clearance issues? I have 80lbrs now and looking to upgrade but do not want to change fuel rail... thnx
Jan 8, 2013 #2 R Rafs-T-Type Not so Senior Member Joined Mar 8, 2009 Messages 2,766 You'll be fine. Your computer is modded for low Z injectors right?
Jan 8, 2013 #3 J jmendlik Active Member Joined Oct 1, 2001 Messages 806 correct--low z modded computer will be used
Jan 8, 2013 #4 R Rafs-T-Type Not so Senior Member Joined Mar 8, 2009 Messages 2,766 You're good to go then.
