153 oil pump setup
kraus
Alright i have a 153 on center stage setup. I have 109 cover with hv gears and a billet pump. It only has 2 ports and adjustable pressure deal on it. So question is owhere all lines go to from etc
I pan has one curved fitting which is pickup. Whichbi was going to run to remote filter housing. Then from there to in on pump. The out then was going to run back to a pan fitting. The turbo return would also return to pan.
Also the feed to turbo would come off filter housing. Unless i can use the smaller hole above timing cover to feed turbo?
Does this all make sense or am i missing something?
Also being i am using 109 front cover, the pan has no front holes. Can i just drill and tap the 2 holes needed up front?
"I pan has one curved fitting which is pickup. Whichbi was going to run to remote filter housing. Then from there to in on pump."
Run the filter on the pressure side of the pump.
