You might end up with a rubbing issue yes. Not to mention thats a lot of backspacing for that size wheel and it might look too tucked under the car. All you can do is see if it rubs and buy spacers if you need them.
Im also working on wheel fitments with a lowered GN. Not all cars are the same, but I can tell you that my 15x8 Pro Stars w/4.5 backspace would not fit without a spacer. That was with a 275/60-15 BFG radial tire. Same tire on 15x8 3.5 backspace & no spacer rubbed on the lip. So if you roll the lip, and go with a 4inch backspace (on my car anyway) your golden! I dont want to roll my lip so Im gonna try 255/60-15 Drag Radial on a 7inch wheel w/4inch backspacing.. Its just a touch shorter in height and a touch skinnier. Im hoping it will fit and it will hook.. Will see
to me 4" is the best backspace... it just that most wheel co don't have that .. I ran 4.5" with a small spacer (5/16's) ... I also have 1/2" wheel studs
IMHO, I have run sapcer for years BUT they are custom made being that the holes are exactly the same size as the studs. IMO they will not be a problem that way.
