SignUp Now!Does anyone know the backspacing of the 16x8 GTA FRONT wheels? May try M&H 275 55 16 28inch drag radials on my GN but not sure if they rub. All info is appreciated,THANX!![]()
Scot, yes they're close to the frame, but if you want, you can always use a 1 1/2" thick wheel spacer to move the whole wheel outboard and not only it increases the tire-to-frame clearance, but it also gives the car a wider stance which makes the car look much better! See this link: Wheel Adapters SpacersI'm after the same thing! With the same rims!
For this car...
255-50-16's on it now and I can't fit my fingers between the frame and the tire..
Claude, Thanks for the link but it's all japanese to me. lol Which ones would I need?Scot, yes they're close to the frame, but if you want, you can always use a 1 1/2" thick wheel spacer to move the whole wheel outboard and not only it increases the tire-to-frame clearance, but it also gives the car a wider stance which makes the car look much better! See this link: Wheel Adapters Spacers
Claude :smile:
Scot W.
Thank you!Scot, the ones you want are the second ones from the top (Wheel Adapter 5 Lug 4.75" To 5 Lug 4.75" Pair). Click on them and it'll open a new page where you'll be able to chose the thickness you want (in my case they're 1.25" thick), that's all...
Claude![]()
Claude, do you have any pics of your car with the 1.25" spacers? Thanks
Eric
does anyone use the rear GTA wheels?
Looks good Claude, those GTA wheels look 100% better when they're spaced out in back.
