1984 Mercury 115 OutBoard question??
Yedi
ya, the Monte over there.
Hey guys, looking for some boat guys here..(I am pretty new to the marine world)
on a 1984 Mercury 115hp outboard, the stock stator is 9amp...I had a 16amp stator installed when the motor was rebuilt. I am now being told from different people that I can't use that stator w/ this motor??
The part number is the same as the Mercury number, except a -16 at the end, meaning 16 amp...
the stator is supposed to have an internal voltage regulator, as the motor does not, just a rectifier.
I wanted a higher output stator because I added a second battery through a perko switch, and have a good size stereo sytem installed.
Trying to put it in the water this weekend, but I dont wanna blow out the CDI boxes, or any other part of the thunderbolt ignition. Any info, would be great!
Go to ScreamandFly.com and look up Jay Smith racing, he is all over that board. Give him a call. When you are done you would have thought you have known him forever. He will help you out.
