Girdled 109, cryoed block,crank and rods, billet main caps,rods are polished with arp bolts, cometic head gaskets,forged pistons,weber Roller cam,pte slic,Aluminum champions heads,arp head studs,t & d roller rockers, roll cage with removable door bars, a/c, century 200 with brake, 9.5 ptc, dual nozzle alky,fast system, fiberglass hood and bumpers, aluminum bumper supports,new tank with racetronix double pumpers -8 up,-6 back, aluminum driveshaft, moser axles,auburn posi unit,metco adjustable uppers, south side lowers. 1.3 60'. pole position tubular front upper a arms that are adjustable. { no more spacers for an alignment} extra drag pack wheels. 15x3 and 15x10 welds.jet hot coat ta headers,3 1/2 downipe with 3''single shot exhaust pipe,frame notch,tin man cold air ATR rear sway bar,autometer shift light,aluminum rear end cover with bearing cap braces,be cool aluminum radiator with oil cooler, spal dual fans,moser axles with extended studs,70mm t/b,auburn pro posi unit,h & r motor mounts etc,etc. $$$$.
