1986 Buick REGAL LS2 T56. It is an iron block LQ9 same as LS2 internally. It has 243 heads and is cammed (230 236 .600 .611 111 LSA) and carbureted with GMPP intake MSD 6010 ignition and is estimated at 520hp and 483ft lbs.. T56 6 speed. 4 wheel disc brakes with SN95 8.8 rear end and 12'' police rotors up front. No rust and paint is good. Glass hood needs prep and paint. Chassis has been heavily modified.
Only con is no climate control, I may go with a trunk mounted a/c system if I have it in the spring.
$12,500
$12,500
