1986 GN Hardtop Central NJ
1Grand86
The car has 134,000 miles on it. I am the third owner and have owned this car since 1999. The motor was rebuilt in 2002 by Dan Smith in Camden NJ, (have put less than 5,000 miles on rebuild). The Transmission was rebuilt by Dynotech and has about 2,000 miles on the rebuild.
The motor was a stock rebuild with ported heads. The Trans has a Dynotech shift kit, Pats 10" 3200 stall LU Convertor, and a larger aftermarket Art Carr trans pan with drain plug.
Some of the Mods done to the car include:
Cottons CPT 65 Turbo, 55 Pound Injectors with modified computer, Walbro 340 Fuel Pump & Hotwire Kit, Billet Adj Fuel Pressure Regulator, 3" Downpipe w/Test pipe and dump, 2 1/2" ATR Stainless Exhaust (Mufflers are not Stainless), Power Plate, Adjustable Wastegate, 3 1/2" MAF w/Translator Plus, K&N Airfilter, Airbags in both springs, Rear Seat "X" Braces, Scanmaster, VDO Guages-Boost, Knock, Oil, Temp, Turbo Tweak Chip.
Misc. Replaced Parts:
Rubber weather stripping around doors including Felt strips, Door Hinges and Pins, GM power window motors, Headliner Recovered, Stock Height springs (Kirban), KYB Shocks, Front ball joints and tie rod ends, Missinig body bushings installed, Powermaster brake accumulator, Front and Rear Brakes are new, S-10 Wheel Cylinders, AC Delco Battery, Alternator, Custom hood insulator pad, Radiator, Water Pump, Coil Pack, Plug Wires, Hoses, and several sensors replaced. Interior is in nice shape, Seats are not torn and the carpet is in good condition. All 4 Tires have about 95% Tread left.
Things the Car Needs:
The car needs to be painted. It has the stock paint and is "Checked" on the top surfaces. The passenger side door will have to be replaced, has rust on the bottom. The rear main seal leaks, The Mufflers need to be replaced. Interior speakers are stock and sound like they are 21 yrs old.
Pictures will be posted soon. Car is located in South Brunswick NJ
Price $11,500 NO Trades. Only selling because I need the money.:frown:
Picture Test....:cool:
Some exterior shots....
:cool:
