1986 T-type price drop 9500.
mikewest_08
Hi I have for sale a 1986 Buick Regal t-type. Car has been a west coast car cali Washington and now Oregon. Lots of mods done to it. Asking $9500 Came factory with aluminum bumper fillers. Gray car with black out package.
Engine mods included
New motor 4.1 out of a 83 wagon
Double roller cam with hydraulic lifters
Turbo tweak chip
Bored 30 over
80cc injectors
Cold air intake
Lt1 3"Maf sensor
72mm tb and plenum
Power plate
66/67 duel ball bearing turbonetics turbo
3" gn1 down pipe
Front mount
Cam need to find specs
New water pump
Aluminum crank pully
New alt
New alum radiator
Alky meth set up
Ac delete bracket
255 fuel pump with hot wire kit
Bigger fuel return line
Adj fuel pressure regulator and fuel gauge
Scan master
Knock, boost, rpm gauge
Wideband o2 sensor
3.5 inch exhaust from the down pipe back
Egr delete
Built trans mission some billet aluminum part 3200 stall converter come out of a car with 750 wheel hp.
Suspension and body mods include
Electric cut out dump
Rear set brace
Air bags in both rear springs
New spring about 1.5 years ago
Driveline safety loop
All 4 rear links adj
Rear shock tower brace
Upgraded front and rear sway bar
Rear disc conversion
S10 front conversion. Knock off rotors now
New front brake lines
Body bushing kit
Have a new full set of bumper fillers
Extra bumper
The bad.
The paint is not horrible but could use paint.
I have a full set of bumper fillers just need painted and put on.
Needs a new bumper strip on front, I have one just needs put on.
You can text if you have any other questions. 505-713-7073
It is still available, but not looking for any trades right now.
Where in Oregon is the car?
