1986 T-type
87chrisss
BLUBYU
Putting my 86 for sale it's a WH1 designer series but painted all black. The car runs hard and strong no problems, It's located in Miami, FL and i wouldn't hesitate to drive it cross country. I bought this car completely stock and i have receipts for everything i have spent. Original Engine matching #'s 88k miles Folder with receipts and misc paperwork. This car runs hard. Interior is fairly clean no holes or rips and interior is original. Car runs on E85, on a SD chip, Has an untouched longblock, with ported tb/plenum and a worked intake smoothened out. Header's were ported and welded. Car has a clifford alarm (top of the line) with the blackjack box which requires a code to drive. Compression is great 150+ on all cylinder's & has great oil pressure.
Has a bunch of parts here's a list of most of the extras. Im sure im missing a few parts, based on 1/8 mile ET/MPH Power is between 490-540hp
New stock re-cor'd radiator
Z06 Fan's custom mounted w, thermoswitch
New coil pack/module
MSD wires (2 months old)
CK trans hardened parts, with deep sump pan.
Dual transmission stack cooler with aux fan
Vigilante (PI) Converter pink 32-3500 LU
GNX body bushings,
Custom pinion snubber (Kirban)
Metco Driveshaft loop
Ground Relocation
High amp Alternator
Red Armstrong Volt Booster
Custom Hybrid Billet 62 turbo (Bison) Maybe 2 months old.
TurboSaver oil relocation kit
3bar map sensor
New Valve springs
New GM lifter's
New Water Pump
THDP downpipe
Dual Hooker Exhaust with Cut out
120# Low imp injectors SD chip
Adjustable FPR
Precision (PTE) front mount intercooler
I replaced gas tank 8 months ago
Dual Red Armstrong pumps
Runs on E85 Ethanol
Billet Aeromotive Fuel Filter
Bigger Rear Sway Bar
Has Upper & Lower control arms
8.5 Girdled/ Rear
Powerlogger
TT SD chip
LC-1 wideband (Just replaced and calibrated a new Wideband sensor)
Modified ECM for Low Impedance Injectors
AC / Heater works
Buick Valve cover's
Powersteering and even cruise control works
Scanmaster 2.2
Autometer Carbon Fiber Gauges - oil/water/boost/afr/ Fuel pressure
Car has a 10 sec pass in her i have ran low low 7s @ the 1/8th @ 94-96 mph before valve spring's! I just changed the valve springs.
786-487-3024
Possible trades accepted prefer cash.
12,000 OBO
Only reason im selling is because i have another one im trying to put together and i would like to free up some cash to finish that one and also sell. I need to buy a house already and need to let go of toys for a bit.
More pics,
Hey Chrisssss, are the rims polished? Or is it really good sunlight & freshly cleaned rims?
Cleaned up i was told you work very close to me somewhere in Downtown. You should swing by sometimes, i was interested in your buddy's aluminum heads but he just never got back to me. I hope i got the right person?!
I actually work in midtown. We should meet up some time. If you're still interested in the heads let me know, I'll give him a call.
Funny i was in Midtown driving around yesterday, yeah man whenever you got some free time let's plan something out, what ended up happening with your car?
