1986 T-type
87chrisss
BLUBYU
Putting my 86 for sale it's a WH1 designer series but painted all black. The car runs hard and strong no problems, It's located in Miami, FL and i wouldn't hesitate to drive it cross country. I bought this car completely stock and i have receipts for everything i have spent. Original Engine matching #'s 88k miles Folder with receipts and misc paperwork. This car runs hard. Interior is fairly clean no holes or rips and interior is original. Car runs on E85, on a SD chip, Has an untouched longblock, with ported tb/plenum and a worked intake smoothened out. Header's were ported and welded. Car has a clifford alarm (top of the line) with the blackjack box which requires a code to drive. Compression is great 150+ on all cylinder's & has great oil pressure.
Has a bunch of parts here's a list of most of the extras. Im sure im missing a few parts, based on 1/8 mile ET/MPH Power is between 490-540hp
New stock re-cor'd radiator
Z06 Fan's custom mounted w, thermoswitch
New coil pack/module
MSD wires (2 months old)
CK trans hardened parts, with deep sump pan.
Dual transmission stack cooler with aux fan
Vigilante (PI) Converter pink 32-3500 LU
GNX body bushings,
Custom pinion snubber (Kirban)
Metco Driveshaft loop
Ground Relocation
High amp Alternator
Red Armstrong Volt Booster
Custom Hybrid Billet 62 turbo (Bison) Maybe 2 months old.
TurboSaver oil relocation kit
3bar map sensor
New Valve springs
New GM lifter's
New Water Pump
THDP downpipe
Dual Hooker Exhaust with Cut out
120# Low imp injectors SD chip
Adjustable FPR
Precision (PTE) front mount intercooler
I replaced gas tank 8 months ago
Dual Red Armstrong pumps
Runs on E85 Ethanol
Billet Aeromotive Fuel Filter
Bigger Rear Sway Bar
Has Upper & Lower control arms
8.5 Girdled/ Rear
Powerlogger
TT SD chip
LC-1 wideband (Just replaced and calibrated a new Wideband sensor)
Modified ECM for Low Impedance Injectors
AC / Heater works
Buick Valve cover's
Powersteering and even cruise control works
Scanmaster 2.2
Autometer Carbon Fiber Gauges - oil/water/boost/afr/ Fuel pressure
Car has a 10 sec pass in her i have ran low low 7s @ the 1/8th @ 94-96 mph before valve spring's! I just changed the valve springs.
786-487-3024
Possible trades accepted prefer cash.
12,000 OBO
Only reason im selling is because i have another one im trying to put together and i would like to free up some cash to finish that one and also sell. I need to buy a house already and need to let go of toys for a bit.
More pics,
Hey Chrisssss, are the rims polished? Or is it really good sunlight & freshly cleaned rims?
Cleaned up i was told you work very close to me somewhere in Downtown. You should swing by sometimes, i was interested in your buddy's aluminum heads but he just never got back to me. I hope i got the right person?!
I actually work in midtown. We should meet up some time. If you're still interested in the heads let me know, I'll give him a call.
Funny i was in Midtown driving around yesterday, yeah man whenever you got some free time let's plan something out, what ended up happening with your car?
I'm not sure what you mean about my car? I'll be taking it to work tomorrow.
