1987 Buick Regal WE4 Turbo T Hard Top
Texas Turbo T
Don't Mess With TEXAS!
1987 Buick Turbo Regal "WE4 - 1 of 1547"
Texas Car Since New! Have the window sticker ! ! ! Clean Experian Vehicle History Report ! ! !
Had been repainted back in the early 1990's. Clear coat has peeled off the hood and trunk. Needs paint and interior. Have new carpet for it already! Have some extra parts that go with the car also. Feel free to contact me if you have questions!
Slide - Photos of My 1987 Buick Turbo Regal
Some of the things I have done to it:
New shocks front and rear (Napa) 2009
New tie rod ends, idler arm, center link, pitman arm. (Napa) 2009
New polyurethane Upper a-frame bushings 2009
New front brake pads 2009
Removed the engine in 2009. Built the engine late 2010
Stock bore, (had block vatted, honed, showed no wear)
Factory Pistons and Rods 3.800 (had rods re-conditioned)
New Rod Bolts (ARP)
Factory heads rebuilt (with Comp Cams 980 springs)
COMP Cams High Energy Pushrods
Edlebrock #5487 Cam & Lifters (@0.050”- 204/214)
New Double Roller Timing Chain
New Head Studs (ARP)
Had crank checked and polished (standard)
New main studs (ARP)
New King rod and main bearings (standard)
New blue printed front cover and oil pump (Earl Brown)
Complete GM gasket set (Factory GM VIN 7 head gaskets)
New motor mounts (Napa)
Factory headers checked and repaired as needed (drivers welded with additional brace)
Starter R&R (installed new brushes)
Alternator R&R (installed new bearings and brushes)
New Intake Bolts (ARP)
New Aluminum Thermostat housing & hold down
Art Carr 9” Non-lockup stall converter (with additional cooler)
Upgraded rear brakes (larger bore “S-10” rear wheel cylinders)
Turbonetics “Cheetah” turbo (with custom exhaust elbow)
RJC Racing Adjustable boost controller
Blue top injectors (ford)
Custom Computer Chip (Turbo Tweak/93 octane, 18 psi boost)
Custom high pressure fuel pump (hot wired)
New Accel Extreme 9000 Spark plug wires
New Autolite 24 spark plugs
Kenny Bell Ram-Air
Adjustable Fuel Pressure Regulator
Casper Electronics Ground Stretcher Kit
New vacuum hoses (most)
Stewart Warner boost/Vacuum gauge (Maximum Performance)
Fiberglass front & rear bumper fillers
$10,500 OBO
Email me at: 87Turbo-T@sbcglobal.net
