Spec my cam please! 4.1 N/A build
Gents .... I'm new to the forum, and reading and learning. I wanted to reply to this thread because i am working my first build and have some cam questions. I acquired several 4.1 blocks, and a truck load full of good "vintage" parts .... none of the parts are of the turbo genre. But I'm doing this 4.1 N/A for my old Jeepster, to replace the blown 231 EF. I have 3 unused Kenne Bell cams. One of them is marked KB 2H, one looks like KB MK 1+ and the other one is KB MK 3R ... I'm thinking of using one of them with flat tappet lifters. The 2H, and the 3R have the original specs cards. I'm trying to figure out the MK1+ ? anybody have any info on this cam ? could it be the MK 1X ? .... any opinions on suitability for a RV type N/A build ? Thanks for looking !
You may want to post in Engine Tech for information on the Kenne Bell cams. More people will see it there and someone is bound to have an old Kenne Bell catalog. They are most likely all hydraulic flat tappet NA cams. I thought an X in the Kenne Bell number was a turbo grind but can't remember anymore.
  • Like
Reactions: JKP
Thanks .... good tip .... the info I have says KB "TX" cams are meant for turbo applications ..... but just curious, what would be the fundamental difference between an N/A cam, and a turbo cam
The whole idea of a performance NA cam is to lift the valves open higher and longer. It's much different for a turbo engine that has boost pressure to fill the cylinders.
  • Like
Reactions: JKP
What condition are these cams in? Id be interested in one. I do have a new 204/214 if you are looking for something like that.
They are all unused, I can send pics, I am looking to sell two maybe all three of them …. If I keep one it would be the mildest of the three. The 3R is for sure a race engine cam… when I get home later today I can post the specs, and pics including the grind cards on the MK 2H, and the MK 3R.
These two KB cams came from a retiring builder in the Riverside CA area. Also obtained several 4.1 blocks, and a bunch of other Buick V6 stull. I have a third KB that is a MK 1 series, i think closest to a stock spec cam. don't have the spec card on this one. I'm building a Jeep motor, so I'm not much interested in higher end race engine stuff.
Those are sweet! I'd like 2nd pickings. There was a Kenne Bell 1XB cam in my NA 3.8, it was a really good cam that eventually flattened a intake lobe.
Id be interested in the 214/228. What would you want for it?
I talked to my builder today, and I will not be using these for my build ... i had already had a new RV Crower cam made for my Jeepster .... if interested text me. ..... 678 492 1924 John ..... jdpolzin and WarWagon have first right of refusal. Not looking to make a lot on these,. just want to see them go to a good home that knows the KB history.
I’ve stashed a 4.1 away for about 20 years knowing I will someday own a turbo Buick, or would swap it. My daily driver is an Olds Cutlass 3.8, and I’d really like to build a hotter n/an engine for it using the 4.1. I always assumed I would be able to get an off the shelf cam when that day came, I guess I was wrong!
I hate to jump in here trying to buy parts, but if you are considering selling cams you’d have JKP I’d like the chance at one of them after Warwagon has gotten what he wanted.
I talked to JKP "John" tonight, he has the Kenne Bell MK2H camshaft still. What style cam are you looking for?
