Spec my cam please! 4.1 N/A build
Gents .... I'm new to the forum, and reading and learning. I wanted to reply to this thread because i am working my first build and have some cam questions. I acquired several 4.1 blocks, and a truck load full of good "vintage" parts .... none of the parts are of the turbo genre. But I'm doing this 4.1 N/A for my old Jeepster, to replace the blown 231 EF. I have 3 unused Kenne Bell cams. One of them is marked KB 2H, one looks like KB MK 1+ and the other one is KB MK 3R ... I'm thinking of using one of them with flat tappet lifters. The 2H, and the 3R have the original specs cards. I'm trying to figure out the MK1+ ? anybody have any info on this cam ? could it be the MK 1X ? .... any opinions on suitability for a RV type N/A build ? Thanks for looking !
You may want to post in Engine Tech for information on the Kenne Bell cams. More people will see it there and someone is bound to have an old Kenne Bell catalog. They are most likely all hydraulic flat tappet NA cams. I thought an X in the Kenne Bell number was a turbo grind but can't remember anymore.
  • Like
Reactions: JKP
Thanks .... good tip .... the info I have says KB "TX" cams are meant for turbo applications ..... but just curious, what would be the fundamental difference between an N/A cam, and a turbo cam
The whole idea of a performance NA cam is to lift the valves open higher and longer. It's much different for a turbo engine that has boost pressure to fill the cylinders.
  • Like
Reactions: JKP
What condition are these cams in? Id be interested in one. I do have a new 204/214 if you are looking for something like that.
