1987 Grand National hardtop 67,000 miles
Rotti54
GRAND NATIONAL
LOCATED in Morris Plains, New Jersey
109 .20 over with Wiseco Pistons
ARP hardware head studs and billet center mains
Stock Rods/Crank
Ported Iron heads with stainless Manley Valves and beehive springs, Harland Sharp 1.65 Roller Rockers with 210/210 Hydraulic Roller Cam
60lb Motron Injectiors/TT Chip
Racetronix 340 fuel pump
Razors ALKY kit
TE44 turbo
New Kirbans Adjustable Fuel Pressure Regulator
Precision Stock Stretched Intercooler
3 inch Terry Houston down pipe
Rear Seat Brace
HR motor and trans mounts
HR lower control arms
New Dual rear air bags
New RJC pulley kit
New Metco angled valve cover breathers
New T/A Rear End Girdle
New Kirbans Vacuum brake conversion
G-Body parts slotted rotors and drums with stainless front lines, I have the rear line but not installed.
New GNS line lock
New but not installed 3.5 Dynotech Aluminum Driveshaft
New Optima battery
New wheel well moldings
New front air dams(GM)
New Kirbans 200amp alternator
New Caspers Voltage Booster
I'm working on putting a new transmission in the car first week of March built to handle the power. The stage 2 transmission in the car currently was starting to act up and could just be the TV adjustment,but I didn't want to take any chances. If you want a better deal without the TRANS work let me know.
Motor work was done by Kevin Hess (turbot990) in 07 has less than 3,000 miles on it since that time. Call or text me 973-479-1682 Matt. $18,500 when TRANS is Completed
This car is rust free with very nice paint, undercarriage is spotless as well. Car has power windows/locks/cruise control tinted rear windows. Has Factory G80 Posi Rear
Wife and I decided to save for another house.
Nice ride Matt, GLWS, is that the other beast in the background?...Mike
I'm in Northern New Jersey, sorry guys I'll add that to the listing.
You still have the one your building? Or is this the one you ended up with?..Mike
No had to cancel the build unfortunately long story, but this is the one I ended up with. It's an awesome GN, but like I mentioned the wire and I decided to pay things off and save for a house. I'll buy another in two years!!!
Whats the deal as is?
Deal is I'm unsure if there is an issue with the transmission or could be as simple as the TV cable is out of adjustment. So it's $16,500 as is or $18,500 with a new transmission.
Took a couple passes at the local track in August 85-90 degrees out little humid. Ran 12.0 @ 114 only turned up to 18psi.
Hey thanks , you should have no problem selling that car , I just got my very first GN back in september so I gotta let my wife settle in to the new one before I jump to another one , beautiful car
Thank you everyone CAR IS SOLD. 87Limitedwo2 bought it! Good Luck with it Justin
Moderators can you please remove this add [emoji106]
