1987 Pearl White Buick Regal Turbo T
GNASTY1987
1987 Buick Regal Turbo T for sale:
Hello guys. I have for sale a 1987 Buick Turbo T with factory astro roof and 82K original miles. Car is extremely clean in and out and has a gorgeous pearl white paint job. Front fillers are new and rear is in great shape. Car has power locks and windows, tilt steering, digital dash, cruise, Astro roof, etc. Interior is a solid 9.5 and I would rate the exterior near a 9. Newer tires, rear brakes, hooker dual exhaust, Bilstein shocks, scan master, adjustable fuel pressure regulator, cold air intake, 3” downpipe, rjc power plate, Denny’s drive shaft, and newer power master. A/C blows cold and heat works as well. Passenger side window is slow to go up. Power antenna works well. Swapped up to 42 lb injectors (obviously new o rings),new 5.7 TT chip, changed out the interior/underhood/trunk light to LEDs, replaced the intake manifold gasket, valve cover gaskets, new PCV grommet/PCV hose/PCV valve, new NGK plugs, new O2 sensor, replaced the front shocks (still Bilstein), replaced the springs with Eibach 1” drop Pro Springs, installed the “T” embroidered floor mats (maroon), newer/better color third brake light assy, normal spring cleaning (cleaned out the intercooler, just changed oil with VR1 10W-30, changed coolant), new 4 ply silicone intercooler couplers with T clamps, replaced the up pipe with a clean, stock factory finish piece, sent out the radio to be gone through and had a 4 ft aux cord added that I routed under the center console and drilled a hole in the ashtray to pull it through (I hate seeing cables), changed rear diff fluid to synthetic and installed TA diff girdle cover, changed out the 4x10s to 6x9 in the rear, purchased a factory astro roof key with instructions and Manilla factory pouch, purchased the copy of the original invoice, purchased a laminated duplicate window sticker.
Asking price: $20.5k
More pictures
More pictures
More pictures
Thank you TurboSkunk15. Looking to get into a burgundy T or another gn. If you’ve got something and are interested in some trades I’m not opposed to it.
