1987 Silver 10 Second T
DSEROVY
TurboBuick.Com Supporter!
Here is my '87 T.
Cool car.
Cold A/C.
Car went 10.8 somthing at 128mph first and only time to the track. I can't bring myself to put a cage in her, as I'm not a drag racer - just like fast cars!
I'm going to try to add pics as time allows, been prettty busy at work!
Car is in NE Maryland - 21015 zip code.
Asking 17k
List of goodies as follows:
.030 TRW forged pistons $300.00
file fit Plasma Moly rings $115.69
New std/std Buick crank - Bought @ 12 years ago at Englishtown new in box! $600.00
stock rods w/ ARP bolts $73.88
RJC girdle w/crank scraper installed $300.00
RJC crank scraper $55.00
Balanced assembly $250.00
Full Throttle Roller cam - 210/215 .516/.516 110 l/s $663.00
Champion GN1 14 bolt heads w/ "beehive" roller spring upgrade $1,629.00
Scorpion 1.55 roller rockers $260.99
ARP head studs $71.88
F/M “wide" bearings $68.00
New Champion intake with billet fuel rails - not ported stocker! $699.00
70mm Accufab Throttle body $220.00
60 lbs Motrons $318.00
new Walbro 340 $100.00
hotwire kit $35.00
F-BODY RADIATOR $130.00
hood mounted Phantom fuel pressure gauge w/hose and fittings $200.00
Accufab fuel pressure regulator $119.99
Cometic Head gaskets $120.00
Rollmaster timing chain $125.00
high flow water pump $50.00
billet water neck $25.00
High volume ported front cover $130.00
Knock sensor $47.95
Precision 6776 Full Ball bearing turbo w s/cover 4" inlet/3" outlet $1,374.99
Turbo water line kit $75.00
hd actuator $60.00
stainless oil drain tube $49.95
RJC boost controller $45.00
Precision turbo saver remote oil filter set-up $150.00
TA Performance Stainless headers $1,000.00
G-body parts 3" Down Pipe $425.00
2.5" Hooker cat back exhaust $360.00
Precision front mount - About the only part I bought used! $700.00
Alky Control - system by Julio - Dual Nozzle $575.00
Dual Fans – Spal $125.00
Caspers dual fan relay kit $64.95
H/R Parts Driver and Passenger poly engine mounts $209.00
H/R Parts poly Transmission mount $89.95
H/R Parts rear sway bar $489.00
UMI Driveshaft loop $49.95
Pat's 3200 stall lock-up convertor $500.00
3 gauge pillar mount $59.00
Extender extreme g chip $89.00
Innovate Wide band XD-16 $399.99
Translator Gen 2 $250.00
Caspers Gen 2 harness adaptor $99.95
4" inlet pipe $150.00
3.5" maf $70.00
K&N filter $50.00
Scanmaster 2.1 $225.00
trans cooler $50.00
Transmission by Brian Hofer w/trans brake, billet drum ,billet input shaft $2,350.00
Denny's Driveshaft - Nitrous ready model with 1350 U-joints & hd rear yoke $580.00
Moser 30 spline axles w/long studs $257.00
True-Trac posi unit w/install kit $545.00
15X6 FRONT CONVO PROS $460.00
15X8.5 CONVO PROS $500.00
275/60-15 MICKEY THOMPSON DRAG RADIALS $340.00
1987 GN front and rear seats - $700.00
Energy Suspension body bushing kit $129.98
Caspers audible knock detector $64.95
Billet vacuum block $39.95
Caspers fan hi/lo switch $39.95
G-body parts silicone vacuum line kit $55.00
Intercooler/turbo hoses @ 100.00 $100.00
Angled bilet IAC boss $59.99
copper turbo gasket $20.00
Phantom temp gauge $59.95
Phantom boost gauge $46.95
Phantom oil gauge $39.95
MSD wires $60.88
Copper header gasket $29.95
Phantom trans temp gauge $46.88
Maf adaptor $10.00
New GM Headlight Bezels $200.00
New GM grill $400.00
New paint $3,000.00
TOTALS Total $24,629.49 (plus a car to install this stuff on!)
Thanks! I don't want to sell her, but last winter here in MD was awful - just trying to play it safe!
Sale in the works! I'll keep you posted.
SOLD! She's going to a good home in sunny California!
Congrats on sale. IMO, this add had excellent presentation, and the price point was dead on. Car is turn key, and generally you never get back more the 50 percent of what you have into the car total.(including purchase)
Others posting cars for sale should take notes from this thread, again JMO.
Update:
Well, after suffering from severe sellers remorse BEFORE selling the car, she's going to stay in the garage! :) WHEW! That was close!
Thanks for all the compliments guys!
fast car..
Update:
There's nothin out there that can match the bang for the buck provided by a fast and tuned right TRs (11s and faster), period. You've got a beautiful motor.
Update:
wow. was the buyer salty?
