General info:
1992 Ford Mustang
Turbo 5.0 AOD.
Green ext.
Tweed Tan interior.
97k on body.
Engine info:
Short Block:
All internals and block came out of a running, 15,000 original miles totaled 1986 Mustang
Short block was torn down and sent to a re-known high performance race engine shop, A.E.S. in Elk Grove, IL
Engine fully balanced and blue printed
Aligned honed
Cross hatched hone ccylinders
Rods reconditioned
Arp Rod bolts
Speed pro file to fit rings
Clevite 77 bearings
Arp main studs
D.s.s. Main support
D.s.s. Windage tray
One piece "no leak" pan gasket
Canton Racing 7qt. oil pan
Valve Train:
Full Comp Cam Valve train
Xtreme Energy: XE270HR-14
Lift .512/.512 Duration 218/224
Comp Cams Push rods
Comp Cams timing chain
Comp Cams hyd. roller lifters
Comp Cams triple valve springs matched to cam # 986-16
Comp Cams valve seals.
Long Block:
Heads port matched to intake
3 angle valve job.
All new keepers and seals
Intake has mild porting
Arp head studs
Turbo Setup:
Cartech Street Sleeper Turbo kit.
Delta Gate waste gate
Pt44 turbo
Fuel System:
Warblo 255 in tank pump
German in-line fuel pump
Cartech Fmu
30pound Ford Racing Performance Parts injectors
Pro-m Universal 3inch Blow Through MAF
Exhaust:
Full 3" turbo back
Dumps out right after drivers wheel
Flowmaster muffler
Test pipe with brand new cat
Trans:
TCI Super Street Fighter
TCI 3000rpm Stall lock up
Less then 1500 miles on transmission
Just replaced this winter
Harden input shaft "the works"
Nice and big trans cooler
Deep sump racing trans pan
Shifts nice and hard and chirps the tires
Suspension:
Saleen Racing shocks all four corners
Energy Suspension poly bushings.
MAC boxed control arms
Sub-frame connectors
Rear End:
Ford Racing Performance Parts 3.73
Ford Racing Performance Parts Posi rebuild
All new seals and wheel bearings
Wheels/tires
16" Pony
225/55/16 in front
245/55/16 in the rear.
Electronics/gauges:
Auto meter Phantom series gauges:
Mechanical ext. mounted Fuel Pressure
Boost gauge
Pyrometer
Double Pillar pod
Apexi Turbo timer and digital o2 gauge
Pioneer Head unit with Aux input for easy Mp3 player hookup
Aftermarket Speakers
Mileage:
Engine: 800miles
Trans: 1500miles
Rearend: 2300miles
I have well over 11,500 dollars tied up in this car. I just returned to college and i need the money for tuition. Asking price 7500 obo. will consider trades. Any questions or comments please email me at mkn8632@hotmail.com
1992 Ford Mustang
Turbo 5.0 AOD.
Green ext.
Tweed Tan interior.
97k on body.
Engine info:
Short Block:
Aligned honed
Rods reconditioned
Arp Rod bolts
Clevite 77 bearings
Arp main studs
D.s.s. Main support
D.s.s. Windage tray
Valve Train:
Comp Cams Push rods
Long Block:
3 angle valve job.
Arp head studs
Turbo Setup:
Pt44 turbo
Fuel System:
Cartech Fmu
Exhaust:
Full 3" turbo back
Flowmaster muffler
Trans:
Suspension:
Rear End:
Wheels/tires
16" Pony
225/55/16 in front
Electronics/gauges:
Boost gauge
Pyrometer
Double Pillar pod
Mileage:
Engine: 800miles
Trans: 1500miles
Rearend: 2300miles
