1st drive on new Razor Alky kit
Sydwyndr
Admin
Staff member
If I were to say that this is absolutely a top notch product, delivering exactly what it says it can do, instructions that are very easy to understand and the customer support is 2nd to none would anyone else agree with with this statement??
TOTALY Agree!!!
Not only that but he includes exactly what you need for the install. Even extras. Down to the solder! Never have i seen a product that includes solder if its needed!
By far the Best product and Best Support!!!!
Thank You Razor!!!! :biggrin:
My Razzors kit just came in . Cant wait to try it out. If it works as good as my SMC kit, i know ill be happy.
ALKY is a wonderful thing !!
Had to be the best mod I have put on my car!
the only mod that has PAID FOR IT'S SHELF over and over again!!!!!!!!!
thanks JD
Awesome product! Step by step instructions made the the job pleasant. I especially like the stock "Power Injection" light when alky comes on :biggrin: . The car runs great but has a healthy appetite for the alky.
Its been just over a year since i bolted it on the 87 and over 100 passes at around 28psi and i just cant say enough .
first time i hit the 11s it was just awesome ,
to be able to drive to and from the track run 11s and never have to look at a race gas pump and be in kill mode 24/7 ..priceless,
oh ,and that julio guy is cool too
now if i can just get him to loan me a system for the 86 so i can say i ran low 10s on alky and 93
Low 10's... how about a high 9 :eek:
Paul.. when you get ready.. hollar ;)
i completely agree, badass service and product. Its so fun to be in kill mode all the time. A couple nights ago a GSXr600 pulled up next to me and wanted to play from a 45 roll. Thinking id be an easy kill, he tried to ride a wheelie while trying to race. Bad move, i started to pull away and by the time he got the front end back down it was too late :D
any problems with smc kit
have you had any problems with the smc kit not spraying but armed light stays on. i have a smc kit about 1 month old car not even driven and the pump doesnt come on sometimes put the armed light stays on all the time :confused:
FBODY-Yes you can. I called Julio at Razor and he said yes. But you have to convert over to the 86/87 ECM, MAF,TRANSLATOR, AIR TEMP SENSOR AND IGNITION MODULE. Then you have a chip made for your combo and tune the car. Then it time to install the Alky. Brad
So just out of curiousity, does the Razor work well with the FAST system. I have a system I integrated into my AEM EMS allowing me to program fail safe options through the EMS.
Example if the pump is charged and there is pressure and I am @ WOT. Boost will go from 19 lbs to 26 lbs, timing is adjusted etc..... Has anyone tried this with the FAST system.
I'll take a look on the alkycontrol board, but any feedback is much appreciated.
