Was pretty excited to try out the new data logging tool. I just got in my stall converter and have no traction until I get my drag radial so my results were somewhat screwed up. I had turned down the boost to around 17psi even though I usually run more just to get some easy baseline runs. Now I have some questions to ask.
What should I be looking for under the Inj. PW. I found a chart of expected values on GNTTYPE.org but had no Inj. PW value to look for. Mine was over 26 (more than 100%) at wot. Does that mean I'm running out of injector?
I just put in a heated 02 sensor just before making my run. The direct scan shows a trouble code for an 02 sensor but I just assumed it was because I hadn't cleared the code with our tech 1 yet. At idle was getting 02 volts as low as 71mV but keeps bouncing around up to just over 700mV. Is that normal? At WOT it is hanging pretty close to the 800mV mark which I think is normal.
What is generally accepted for the knock cnt? Evidently I had a knock count of 2 before I even started my fun. On my time slip it shows 2/0 giving me a total of 4 for the day. I was expecting 0/0 because I had the boost turned so low this time. I actually still had some race gas mixed with my 92 so with 17psi is this normal? How much can I turn up the boost and not worry? My peak knock Rtd was 4.4 as the knock was occuring. GNTTYPE.org says that <6 is o.k. Any advice?
Thanks for any input you can lend. I'd really like to get all of this stuff figured out so I know I'm not hurting anything.
Eric Malmsten
Ishpeming, MI
Eric Malmsten
Ishpeming, MI
