2-step launch controller
Junior Samples
Walk Away
This gizmo is sweet, But I have to get rid of some stuff due to needing cash flow asap
I wish I could keep it but it has to go
Has your dip switches to set your rev limit, your launch rpm, so you set it to your stall and put it to the wood and it wont go over your set rpm.
Also has studder rpm switch so you can studder your rpms at say 200rpm under your stall.
Can also set your launch timing retard to help heat up the spool.
I hooked mine up to my car horn so if i flipped switch one way I had horn, flip the other way I could control launch off the horn
Sells for $229.00 new
yours for $180.00 shipped
