dank GN
BlackArts Automotive (661)993-8277
- Jan 11, 2009
Can someone experienced explain how you can hold the car without moving with just a 2 step @ 3k and 20psi boost?
I am not a expert this is just my opinion on your frustration .the 2 steps sole purpose isn't to build boost although it is a great aid to help with that. That's why ppl have a trans brake in conjunction with the 2 step so the motor does have some sort of load on it . If you pull timing while the 2 step is actavated it will add heat in the exsaust which will help build alil more boost but again if you where under the impression that just adding a 2 step would cure any boost issues idk what else I can say about this. O yea and having a quality boost controller with C02 and a launch boost setting will also help greatly. I am running a external gate with no spring just co2 so I am 100% positive that my waste gate is pinned shut allowing all that super heated exsaust to flow through the turbine and not by passing it
